mightyram50.net • View topic - 4D55 Injection Pump Wanted
Need a part? Post in here to see if someone has it.
Forum rules
All Wanted Item Are Automaticly Removed After 60 Days.
Postby 85TDW50 » Thu Oct 28, 2010 6:12 am
I'm looking for an Injection Pump for a 4D55, With Timing Gear/Sprocket and Nut & Lockwasher too.
Got screwed on one i bought on ebay from the UK, took me over 3 months to get my money back. So i didn't try to buy one for a while, felt a little leary about buying anything on ebay.
84 Dodge Power-Ram 50 Turbo Diesel
92 Dodge Dakota 4x4
76 Dodge Ramcharger
74 Plymouth Duster 340
73 Dodge Dart Sport 340
72 Dodge Demon 340
71 Plymouth Duster 440
70 Plymouth Duster 340
65 Plymouth "Formula S" Cuda 273
85TDW50
Engine Size: 2.3L
Re: 4D55 Injection Pump Wanted
Postby wrngwae » Fri Oct 29, 2010 8:59 am
y9ou could just find a "good" diesel shop and have your rebuilt,,,,,,,that is if you have one. it should be around 6hundo........give or take. is your pump leaking at the timing gear? IF NOT THAT IS ALOT BETTER.
or Chinese parts!!!!
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Postby 85TDW50 » Fri Oct 29, 2010 11:47 am
wrngwae wrote:y9ou could just find a "good" diesel shop and have your rebuilt,,,,,,,that is if you have one. it should be around 6hundo........give or take. is your pump leaking at the timing gear? IF NOT THAT IS ALOT BETTER.
My pump is royally f'ed. Alot of external damage (i have a feeling there are hairline cracks in the body/housing too), the engine came from a wrecked truck.
EDIT : Found a pump.
92 Dodge Dakota 4x4
76 Dodge Ramcharger
72 Dodge Demon 340
85TDW50
Engine Size: 2.3L
Return to Wanted
