mightyram50.net • View topic - 96 Instrument cluster hood
Need a part? Post in here to see if someone has it.
Forum rules
All Wanted Item Are Automaticly Removed After 60 Days.
Postby khrome61 » Sat Jan 15, 2011 12:48 pm
Looking for an Instrument Cluter Hood for 1996 Mighty Max.
khrome61
Engine Size: 2.0L
Re: 96 Instrument cluster hood
Postby mikewarme » Sat Jan 15, 2011 6:27 pm
What color?
mikewarme
Engine Size: 2.3
Postby khrome61 » Sun Jan 16, 2011 2:42 pm
Any Color
khrome61
Engine Size: 2.0L
Return to Wanted
