mightyram50.net • View topic - Weatherstrippin
Weatherstrippin
Need a part? Post in here to see if someone has it.
Forum rules
All Wanted Item Are Automaticly Removed After 60 Days.
Weatherstrippin
Postby mikewarme » Mon Oct 26, 2009 8:12 pm
Mike I say you and I obsolete all the weatherstrippin they have left
mikewarme
Engine Size: 2.3
Re: Weatherstrippin
Postby pennyman1 » Tue Oct 27, 2009 5:44 pm
Metro is now making door gaskets for 1st gen d50s and there are 2 or 3 people making 1st gen windshield gaskets
pennyman1
Re: Weatherstrippin
Postby mikewarme » Sat Dec 19, 2009 5:50 pm
Metro is not Pennyman. Everyone selling them is selling incorrect shit! Google the metro numbers it comes back as dakota. And the 1st gen weatherstrips aftermarket suck
mikewarme
Engine Size: 2.3
Re: Weatherstrippin
Postby pennyman1 » Sat Dec 19, 2009 7:36 pm
I stand corrected. I should have known it was too good to be true. Thanks Mike for setting the record straight!!!
pennyman1
Re: Weatherstrippin
Postby mikewarme » Sun Dec 20, 2009 6:42 am
Well, the windshield weatherstrip is ok aftermarket if its all you can get , better than nothing! But they charge anywhere from 50-70 for aftermarket and Genuine mitsu is less than $70. So what would you get.
mikewarme
Engine Size: 2.3
Return to Wanted
