mightyram50.net • View topic - WTB Automatic transmission for gen 2 - 1987
Need a part? Post in here to see if someone has it.
Forum rules
All Wanted Item Are Automaticly Removed After 60 Days.
Postby jwwiff » Sat Sep 18, 2010 6:38 pm
Looking for a Mitsubishi automatic transmission for a 2.6L engine - Dodge Ram D50, 1987.
jwwiff@aol.com
jwwiff
Engine Size: 2.6L
Return to Wanted
