mightyram50.net • View topic - 89 2.0L alternator
89 2.0L alternator
Need a part? Post in here to see if someone has it.
Forum rules
All Wanted Item Are Automaticly Removed After 60 Days.
89 2.0L alternator
Postby steve-0 » Thu Sep 30, 2010 7:28 pm
yah crap just keeps piling up.
need an alternator for an 89 2.0L non ps if matters
email me at stephenstein69 at sbcglobal dot net
fluffy bunniz
steve-0
Re: 89 2.0L alternator
Postby steve-0 » Sun Oct 03, 2010 11:38 am
anybody?
fluffy bunniz
steve-0
Postby steve-0 » Sun Oct 03, 2010 4:31 pm
the 2.4L alt also works for my application.
fluffy bunniz
steve-0
Return to Wanted
