powersteering gear box oil seal
Need a part? Post in here to see if someone has it.
Forum rules
All Wanted Item Are Automaticly Removed After 60 Days.
Postby djb1989 » Wed Oct 20, 2010 4:35 pm
Looking for an oil seal for my 1989 power steering gear box the one next to the pitman arm any help?
djb1989
Re: powersteering gear box oil seal
Postby mikewarme » Sun Oct 24, 2010 5:25 am
rockauto.com or go to dealer
mikewarme
Engine Size: 2.3
Postby djb1989 » Tue Oct 26, 2010 11:58 am
mikewarme wrote:rockauto.com or go to dealer
Thanks dealer is not much help, but I will try rockauto.
djb1989
Postby Boomer » Tue Jan 04, 2011 10:35 am
NAPA has them if not they can order
Boomer
Postby mikewarme » Tue Jan 04, 2011 8:50 pm
Explain why dealer isn't any help? I just ordered seals from them for my gearbox.
mikewarme
Engine Size: 2.3
Postby sassafrass » Thu Jan 06, 2011 6:06 pm
i tried ordering one from NAPA and it was the wrong one. rock auto had the same part number. it is a metric seal. you can measure it with a caliper or take it down to a bearing shop. they can measure it for you. i ended up ordering mine online as the seal wasn't a stock one. it was about $2. i don't remember but i think it was 17x32mm or some such.
tom
sassafrass
Engine Size: 2.3
Postby mikewarme » Fri Jan 07, 2011 12:09 pm
The dealer is easiest
mikewarme
Engine Size: 2.3
Return to Wanted
