mightyram50.net • View topic - Alternator
Alternator
Need a part? Post in here to see if someone has it.
Forum rules
All Wanted Item Are Automaticly Removed After 60 Days.
Alternator
Postby defwin » Sat Dec 11, 2010 10:01 am
Looking for a good buy on a alternator for a 89 2.6l.
May have some parts to trade for a 89 d50.
Thanks
Don
ziton@msn.com
defwin
Engine Size: 2600
Re: Alternator
Postby defwin » Mon Dec 13, 2010 9:00 am
Got one.
defwin
Engine Size: 2600
Return to Wanted
