mightyram50.net • View topic - lower plastic timing cover 4d55 83
Need a part? Post in here to see if someone has it.
Forum rules
All Wanted Item Are Automaticly Removed After 60 Days.
Postby trevor w » Wed Mar 23, 2011 9:22 pm
need lower plastic timing cover for 83 diesel 4d55 the one with TDC mark on it, in good shape. will take upper too if have nice one. my upper is not that great . trevorw 83 diesel
trevor w
Engine Size: 2.3
Return to Wanted
