mightyram50.net • View topic - My '74 Plymouth Duster & '65 Plymouth 'Cuda
Postby 85TDW50 » Sat Jan 30, 2010 8:12 am
Here are 2 of my babies
First off is my (far from original) '74 340 Plymouth Duster. Running a 1970 340 T/A (6-Pack) engine, bored .100 over :shock: Forged Domed Pistons, 12:1 Compression, 340 T/A (J) Heads, 484 Lift Mopar Performance "Purple" Camshaft, '71 340 4BBL Intake (because i can't find where i put the 6-Pack Carbs) with an 850cfm Thermoquad carb, Aluminum Rods, Forged Crank, Balanced Rotating Assembly
Backed by a Torqueflite 727 with a Full Manual Shift Kit and an 8-3/4" Chrysler Rear End (489 Case) with Sure Grip & 4.10 Gear Ratio
It also had quite a few factory options like A/C, Rear Defrosters, Rallye Wheels, Rallye Mirrors, Internal Hood Release, Light Package, ect
http://s182.photobucket.com/albums/x42/ ... 000927.flv
And here's a shot of it parked by my dad's (mostly numbers matching) '73 340 Plymouth Duster (with 56,000 original miles on his car :shock: Mine has 103k on it)
And my 1965 "Formula S" Plymouth Barracuda, i picked this baby up about a year ago for $800, with the original 273 still under the hood. It had been parked since 1986, but after cleaning the Points, throwing a battery in it and filling an Antifreeze Jug with gas it fired up and purred like a kitten :D
(yeah that's my '72 340 4-Speed Dodge Demon parked beside that Caravan.. Numbers Matching Car with every option available :shock: )
Original AM Radio and it still works great too!!
84 Dodge Power-Ram 50 Turbo Diesel
92 Dodge Dakota 4x4
76 Dodge Ramcharger
74 Plymouth Duster 340
73 Dodge Dart Sport 340
72 Dodge Demon 340
71 Plymouth Duster 440
70 Plymouth Duster 340
65 Plymouth "Formula S" Cuda 273
85TDW50
Engine Size: 2.3L
Re: My '74 Plymouth Duster & '65 Plymouth 'Cuda
Postby crvtec90 » Tue Feb 02, 2010 6:55 am
good stuff man. I dig mopars too. Check out ......forabodiesonly.com theres a lot of info and parts
Drive it like u stole it
crvtec90
Postby 2.0 wonder » Mon May 31, 2010 10:14 am
I used to own a 74 and a 71 Twister, those are really fun cars to work on and to own.
2.0 wonder
Return to Other Vehicles
