Class 6 Off Road Race Truck D-50 build out. Chevy. 4.3L V6
A place to post a build thread for your 1st Gen truck.
(1979-1986)
Forum rules
Re: Class 6 Off Road Race Truck D-50 build out. Chevy. 4.3L
Postby 4doorciv » Thu Nov 25, 2010 12:42 am
It does look pretty tight in that bay. How's it taking apart and outing back together?
-Ryan-
4doorciv
Engine Size: 4g63
Postby Wilbur » Tue Dec 07, 2010 9:22 am
If they were EME you might be dissolving in a 55 gallon drum right now. Nice scam...
Wilbur
Engine Size: 2.4
Postby 4doorciv » Tue Dec 07, 2010 10:35 am
What scam?
-Ryan-
4doorciv
Engine Size: 4g63
Postby camoit » Tue Dec 07, 2010 4:11 pm
Wilbur wrote:If they were EME you might be dissolving in a 55 gallon drum right now. Nice scam...
What is EME? And what scam?
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Postby Wilbur » Sat Dec 11, 2010 8:24 am
Your cop for parts to score the trans and motor.
Wilbur
Engine Size: 2.4
Postby camoit » Sat Dec 11, 2010 12:36 pm
Wilbur wrote:Your cop for parts to score the trans and motor.
OK now I under stand.. It's not my fault I look like a cop and I can play with tweekers paranoia to my advantage.
camoit
Admin
Admin
Engine Size: 2.6L
Postby 4doorciv » Sat Dec 11, 2010 6:51 pm
Haha. Nothing wrong with that. I get cheap stuff from tweekers all the time.
-Ryan-
4doorciv
Engine Size: 4g63
Postby crvtec90 » Sun Dec 12, 2010 10:13 am
Those are some serious pipes! Now Im tweakin. :o
Drive it like u stole it
crvtec90
Postby camoit » Fri Feb 04, 2011 11:27 pm
Time for a quick update.
Here is the KRC Pully system and power stearring pump. The warter pump is a Stewart stage 4 water pump. It pumps 120 GPM @ 48 PSi. I need the high volume and pressure to pump the water to the raidator located above the engine and in the rear of the truck. The High PSI is to break through any steem pockettes that may rear there ugly head when running it hard.
Here is the installed 4 inch Air Bump stops on the front end. The Fox Bump Stops will be pressurized some where around 250 PSI with Argon. Why Argon? Argon has a larger atom then Nitrogen and is a true inert gas unlike Nitrogen that is realy close. Nitrogen causes the oils in a shock to foam. But it is less expensive. But since I have Argon I'll use it. Other wise I would need to get a tank of Nitrogen.
This is the front end at full bump. I limited the front to 13 Inchs of wheel travel on the front end.
Here is where the spair tire will be located on the back of the truck. I only took about 6 hours to come up with the final location. I had to work it around the batterys that are located dirctly under it. The Raidator is a CBR 3 core duel pass 16" X 32" It is rated up to 1100HP for BTU displacement. It also has duel electric fans.
camoit
Admin
Admin
Engine Size: 2.6L
Postby natureboy » Sat Feb 05, 2011 1:04 am
Man that's a thing of beauty! I used to do a bit of desert racing in So Cal 20 years ago and was always amazed at how fast the built trucks could pass me on my Honda XR at 80 mph. And a little jealous. Okay, murderously envious. I probably shouldn't look at your posts and blog anymore, I think my wife would do a Lorena Bobbit if I started something like that. :naughty:
natureboy
Engine Size: 2.6l
PreviousNext
Return to 1st generation
