Alternate Brake booster for...?
A place to post a build thread for your 2nd Gen truck.
(1987-1996)
Forum rules
Re: Alternate Brake booster for...?
Postby 77amc » Wed Feb 10, 2010 7:13 am
At work we have a few hundred 'tugs' that pull around the baggage carts and some have brakes that will put you into the windshield and some that will put you into the side of a plane..
I guess it would depend on your foot 'till you get the feel of it. But if someone built up a 'big brake' setup, they wouldn't have to worry about fluid pressure. I guess a adjustable proportioning valve would be a must.
I'll see on this Hornet later this spring when I start tearing into it.
Another thing I thought of was to use an adapter at the rear or bumper that one could extend that high pressure to a trailers braking system that would have one way valves.. Just a thought though.
E
77amc
Engine Size: 2.6
Postby pennyman1 » Wed Feb 10, 2010 7:43 pm
Extending brake lines to a trailer is not only illegal, but it is dangerous as well. 1 leak and everything loses braking. Even the old brake controllers that tied into the brake lines from years ago are illegal for the same reason. 1 way check valves won't work either, once they are pressurized they won't release
pennyman1
Previous
Return to 2nd Generation
