 by 4doorciv » Thu Dec 16, 2010 4:19 pm
			I did my swap with a parts car and regretted it. If you are going to keep the engine in the stock location then the factory g63b engine mounts are perfect. Unless you want to move the engine forward 3 inches and make things more accessable in the rear of the engine then modified engine mounts and cross member are required. As well as a modified driveshaft. The stock location for the engine will require you to modify the firewall to have room for the cas and waterneck that sticks out about 2 and a half inches with the 1.8 waterneck from a 90 or so eclipse. The 7 bolt engine that has the cas on the gear part of the cam and a crank sensor would save some space as well as the front exit from jay racing but of course you are going to have to custom a plate on one of the mounts because of the lack of threaded holes for our engine mounts. Hope you have a plan for everything. Don't you wanna start a new thread to gather information?
			-Ryan-
1992 Honda civic b18c1.  -sold-
