My 87 white mits build
(1987-1996)
Forum rules
Re: My 87 white mits build
Postby 76dually » Fri Oct 01, 2010 5:27 pm
are you gonna ahead and cut a inch out of your lower control arms while your that far into it?
1988 mighty max, bagged, body dropped, RHD, under total reconstruction
1997 2wd 4dr dually. project to be.. 6.5 diesel layin frame on some 22in alcoa (soon)
76dually
Postby laidoutmits » Fri Oct 01, 2010 5:54 pm
ok I'm not fermiliar with the uniballs so please school me, and no on the c.a. If I understand what u mean I am goin a different route. If that is how u did yours post some pics cause I would like to see it ,thats is an intresting way.
laidoutmits
Postby laidoutmits » Fri Oct 08, 2010 7:01 pm
Ok so I have to add to the story that after I had already finished welding the upper and lower control arms I found out the 18's I had been runnin and was planing on using after the bag job weren't ganna work cause the back didn't tuck. Sucks!!!!
So the plan for the project needed to be modified with that being said I went and got second job at hooters just to pay for the new set of 20's I wanted. So with tucking the 20's I added some drop spindles and re-did another pair of control arms to bring the spindle to 25 1/2" (13 1/2" for half the 27" tire plus 12" for frame to ground height).
laidoutmits
Postby laidoutmits » Fri Oct 08, 2010 7:20 pm
now to continue with the fab work on the bag mounts and new upper control arm mounts.
laidoutmits
Postby laidoutmits » Fri Oct 08, 2010 7:29 pm
ok now that I have found the location for the bottom and top bag mounts and the upper control arm mount I started revese mocking to them so I could then build to where they need to be.
and now here are the parts I used as factory or base points
laidoutmits
Postby laidoutmits » Fri Oct 08, 2010 7:43 pm
Now I'm ready to make the new parts and fab up to the mocks. Here is what I need to mach to. these are basicaly the actual control arm side and the top of bag thats represented.
next I bolted my top bag mout up and made the new mount
laidoutmits
Postby laidoutmits » Fri Oct 08, 2010 7:47 pm
ok here are the fab plates ready to be welded
laidoutmits
Postby laidoutmits » Fri Oct 08, 2010 7:51 pm
Now with the mounting plates made its time to make the supports for them.
laidoutmits
Postby laidoutmits » Fri Oct 08, 2010 7:54 pm
laidoutmits
Postby laidoutmits » Fri Oct 08, 2010 8:23 pm
with both sides now done its time replace the strut arm assembly with a custom lower control arm now. First I made a tool to give me the spacing then I started making the brackets.
laidoutmits
PreviousNext
Return to 2nd Generation
