4doorciv wrote:I'm sorry but I don't quite understand the consept of the square tubing designed like that. Also, removing the engine mounts tells me you won't be using the 2.4 anymore, or you are going to do a body drop and modify where the engine sits in the bay.
4doorciv wrote:Ah. Okay. I was wondering about the design. Have you given any thoughts on rolling the pinch? Also I remember a few builds on mightyd50 that layed frame without z-ing it. They pie cut the upper and lower control arms, and that's all I remember. It was a while ago.
pennyman1 wrote:The Ram50/MM frame needs to be z'd to lay totally flat because the front crossmember sits too low in relation to the rear, causing the front to sit higher than the rear. Raising the front crossmember puts the bottom of the crossmember flush with the frame. Z'ing and new carrier and tranny crossmembers will make the frame totally flat side to side and front to rear. Definately not for the novice; btw great work on all the mods, much more than I can do. That's why I have friends that build race cars make the parts i need, it's worth it to be safe to me.
4doorciv wrote:Makes sense. Maybe that's what the guy did. Oh well. Please keep up the good work.
