mightyram50.net • View topic - it is time, for sale 87 dodge raider w/4d55 swap
Have a part to sell?
Do you have a service you offer? Post it here!
You must have 50 posts before you can sell in this forum.
Forum rules
All Topics Are Removed After 60 Days.
As Of 11-13-10
YOU MUST HAVE Minimum Post Amount Of 20 Befor You Can Sell Parts Here.
Postby wrngwae » Sun Dec 19, 2010 12:46 pm
it pains me to place this vehicle up for sale as i have an uncountable amount of money and hours in the vehicle. but here we go. this project started ad an 84 ram50 diesel that had more wiring and rust issues than you can save. so i pulled the motor and rebuilt it. it has has the balance shafts removed and the rotating mass has been balanced. the block was hot tanked and professionally cleaned. with fresh polishing on the crank and and itm pistons. new cyl sleeves and trued deck not too much. i ended up purchasing the raider and pulled the 2.6 auto. after modifying the starter it fit the flex plate properly. so it is mated to a fully functional auto with the proper overdrive thermo switch as well. everything works as it should. accept the tac which i never really dove into. but it can work properly with dakota digital kit. it also has fully functioning A/C with a very hard to find Mitsubishi bracket and compressor with custom fit hoses to properly match the raider system. this is no hack job i have done. it has operational head light squirters and rear defrost w/ rear wiper. while the motor was out i went and descaled the frame and engine bay. the frame was por15ed thru out the entire frame and what was left underside of it. it has the proper fuel filter/heater assy with a new Honeywell temp controller. a fresher rebuild on the turbo which was upgraded to a water cooled housing that is hooked up. im sure there is a ton of stuff im missing but i will add as i think of it. it also has a less than a year old optima red top battery. it also has aftermarket 16" rims with good 235/75/16 tires. newer brakes and odds and ends. there is about 40000 on the motor and 96000 on the truck. im really trying to get $2000 for it as a very good price but im open for discussion. the reason for the sale is i got the wife a new ride for Christmas, an 07 H3.
oh yea, rebuilt injectors about 15thousand miles ago. and a holly fuel pump for lift since the injection pump does both to help with mileage and longevity. and i did a starquest inner cooler install to without destroying the front end and looks.
or Chinese parts!!!!
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Re: it is time, for sale 87 dodge raider w/4d55 swap
Postby wrngwae » Sun Dec 19, 2010 12:58 pm
see my Gallery for pics i just uploaded
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Postby bellavesus » Sun Dec 19, 2010 2:10 pm
Oh man, its an auto? if it was manual i would be all over it. what is the fuel mileage, how does it do on the highway and hills? you have done an amazing amount of work on it, $2K is quite low, that is a serious deal.
bellavesus
Postby wrngwae » Sun Dec 19, 2010 7:38 pm
it gets about 22 or so mpg and it drives the toll road at 70mph. and the auto works fine with a nicely modified kickdown linkage assy.
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Postby mikewarme » Mon Dec 20, 2010 5:49 am
ebay tye! How much the H3 set you back?
mikewarme
Engine Size: 2.3
Postby MainstreaM » Mon Dec 20, 2010 7:49 pm
Or sell it to me. ;)
Kane
MainstreaM
Engine Size: 4g64
Postby wrngwae » Tue Dec 21, 2010 4:28 am
Hey Kane talk to me bro........i havent got any pm's yet?????
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Postby wrngwae » Tue Dec 21, 2010 8:03 am
someone coming out Tuesday after Christmas.....
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Postby cdalejef » Thu Dec 30, 2010 9:10 am
Did that guy buy it?
89 Mazda B2600i soon to be 4d56 turbo diesel.
99 Mitsubishi Montero SR
cdalejef
Postby wrngwae » Thu Dec 30, 2010 6:06 pm
mainstream aka Kane will be picking it up soon but if it falls thru i will update it for ya.
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Return to For Sale
