mightyram50.net • View topic - Pair of 87 Starion/Conquest LSD with 3.54 gears
Have a part to sell?
Do you have a service you offer? Post it here!
You must have 50 posts before you can sell in this forum.
Forum rules
All Topics Are Removed After 60 Days.
As Of 11-13-10
YOU MUST HAVE Minimum Post Amount Of 20 Befor You Can Sell Parts Here.
Postby Mojave Magic » Mon Dec 20, 2010 8:54 am
I have 2 complete limited slip differentials from 87 Starions. One had 70k the other had a little over 100k. Tagged for 3.54 gearing and the rest of the car was stock, so I don't think they were swapped. They are in storage right now, but I can check on the gearing sometime to be sure. I sold my truck and these are the last parts sitting around. They spin smoothly and don't seem to have any defects. The fluid in them looked pretty good and not burnt up.
Will split up the LSD guts and 3.54 gears if you want. Looking for $200 and I'll split shipping on one whole diff. Or $100 + shipping for each LSD or set of gears, your choice. Again I have two complete diffs. Best bet is to Pm me, because it will send an email and I check that everyday. My zip is 12566 and pickup would be much easier than shipping, but I'll do it if I have to. I also make my way to NJ from time to time and my family also makes a trip to VA too, so we may be able to work something out. No pictures with them in storage, but they wouldn't show much anyway.
1988 Power Ram 50 75k miles SOLD :(
1998 Ram 3500 quad cab SLT Laramie 5.9 12v Cummins
Mojave Magic
Re: Pair of 87 Starion/Conquest LSD with 3.54 gears
Postby Mojave Magic » Mon Jan 24, 2011 8:36 am
Still have these. Open to offers. I'm not really looking to get killed, but this site was a big help when I had my truck, so I'm not opposed to giving someone a good deal either. Someone has to have the need for a winter project.
Mojave Magic
Postby plh » Tue Feb 01, 2011 6:48 pm
If these were '88s I'd jump on them
plh
Engine Size: 2.6l
Postby Mojave Magic » Wed Mar 09, 2011 9:08 am
It's been a bit of a mess with the site changes. Time to bump these up. Make me an offer.
I checked and they are 25 spline, so I guess they go in the front of 4cyl trucks, but I can't find the axle specs to be sure. The ring and pinion should work in the rear though after looking at part numbers. Someone has to need some 3.54 gears with gas going up. My brother is going from NY to VA sometime this weekend, so I can have him drop them off on the way if it's not too far.
Mojave Magic
Postby wrngwae » Fri Mar 11, 2011 4:28 am
it may help if you state 6 bolt or 4......87 wide body or 87 flatty
or Chinese parts!!!!
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Postby Mojave Magic » Mon Mar 14, 2011 12:21 pm
They are both 4 bolt from 87 widebodies.
Mojave Magic
Return to For Sale
