4x4 vs 2wd
Forum rules
4x4 vs 2wd
Postby Aeroheadcww » Mon Sep 14, 2009 6:01 pm
I was just wondering, is there a difference in the chassis between the 4x4 and 2wd RAM50? I have an 89 long bed that is in near perfect condition, except the paint, but I really need a 4x4 and I was wondering if the transfer case, axles, etc. could be bolted onto my truck if I could get a 4x4 donor. Can you use parts from a montero as well? Thanks for any help. :D
Aeroheadcww
Engine Size: 2.6
Re: 4x4 vs 2wd
Postby Spicoli » Mon Sep 14, 2009 6:36 pm
Frames are quit e different lots of weld on x member mounts and brackets no on the 2wd, Monteros are very similar cept there a schosh bit narrower. If you really want to make a 4x4 out of yourexisting 2wd, bust out the torch and welder and SAS it
--keRby
Ad Inexplorata
Spicoli
Re: 4x4 vs 2wd
Postby capev86 » Sat Dec 18, 2010 9:55 pm
i drove my 87 ram 50 short bed, std cab, 2.0 5spd, manual steering, etc through the winter a couple years ago and it did ok enough that i want to keep it the roadster (rwd) configuration for the other 9 months of the year. decent tires make a difference as well as having some weight in the back (my dad's had luck with 2wd suburbans). big issue is the open differential. i have seen 4x4's spinning one tire at each end and people tend to get over confident with them whereas i would save the 4x4 capability just to get out of a bind. i'm thinking a locking diff and softening the rear axle gear (3000gt awd 3.3 rear diff ring/pinion?) would help quell the peg-leg personality traits of 2wd pickups in winter driving.
some of the (available on 4wd only) pieces i want to pick up for my truck eventually:
skid plates - if they will bolt onto a 2wd as i do take the truck off road, live on a dirt road, etc.
87 power ram, raider/montero 15 inch 5 spoke rims that look like the stock 14's on my truck
capev86
Engine Size: 2.0
Re: 4x4 vs 2wd
Postby camoit » Sat Dec 18, 2010 10:53 pm
I would get somthing like an old bronco and drop the body on it. Now that is a mod the board is dying for.
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Return to All 4WD Trucks
