Lowering
Suspension Drops, Air Bagging, and all Ground Slamming Modifications.
Lowering
Postby eastwood » Sat Oct 23, 2010 5:58 pm
Im from NZ and got a 1985 Mitsubishi L200, same as the 1st generation d50 or mighty max.
the plan is to keep it stock, but lower the f@#k out of it.
My question is what would be the best way to lower the front? Compressed? lowering springs? cut?
aslo, if i do lower the front end, would i have to modify anything else?
Im semi noob, this is my first 'project' car. . .
Any help or suggestions would be great
eastwood
Engine Size: 2L
Re: Lowering
Postby camoit » Sat Oct 23, 2010 6:41 pm
I here from others on the fourm there are lowering spindles. My first question to you is do you have a welder?
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Re: Lowering
Postby eastwood » Sat Oct 23, 2010 7:57 pm
I don't own a welder, however i am able to get hold of one. . .
eastwood
Engine Size: 2L
Re: Lowering
Postby camoit » Sat Oct 23, 2010 11:39 pm
This is a test since I changed the catogary. Please try to add a reply. If you can not please send me a PM.
Thank you.
At least you have access to a welder. You will need one if you go any way other then lowering spindles and blocks.
camoit
Admin
Admin
Engine Size: 2.6L
Re: Lowering
Postby DroppedMitsu » Mon Oct 25, 2010 10:19 pm
For the front I would throw some 2" lowering spindles on it, which can only be bought from airbagit.com. if you want it lower throw some 2.5" lowering coils from the same place. For the back throw on some 4" bloxks and if u want it lower pull out the middle leaf to get another two inches
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Return to Suspension / Lowering
