Ok for the 4 link, if I'm not mistaken, it would be best to weld it on with the truck at stock height? Would that give me perfect pinion angle all the way? Or is there another way to do it? I just thinking i would remove the entire bed, gas tank, and leave the rear axle untouched and with the wheels on, then weld the 4 link on. Would that work?
Also I made a new cart at airbagit.com let me know what you guys think. Look about right since I'm sticking with the 1/2" set up?
Also what do you think about the 2cycle manifold valves (6th on the list)? It's a 2 cycle manifold (2 valves in one)? Ever used em? Should I stick to the single valves? I just thought it would be a little better since I want fbss, and I can put one of these on each corner.... Link under pic..
And here's the link for the 2 cycle valve manifold...
http://www.airbagit.com/ProductDetails. ... C&CartID=6
