Brake booster
Brake booster
Postby MightyG54BTMax » Sun Sep 20, 2009 4:04 pm
Any one have pics of a brake booster off a 2nd gen 2wd 2.0 (don't know if all that stuff matters)? It would be even better if anyone had measurements of the spacing between the 4 bolts it mounts with. I don't want to take mine off if my Frankenbrake idea isnt going to work from the get go.
MightyG54BTMax
Engine Size: 2.6
Re: Brake booster
Postby Spicoli » Sun Sep 20, 2009 6:22 pm
Wanna explain your frankenbrake idea? And then maybe youll get some measurements :mrgreen:
--keRby
Ad Inexplorata
Spicoli
Re: Brake booster
Postby MightyG54BTMax » Mon Sep 21, 2009 2:27 am
Im thinking of running my conquest master cylinder for the bigger bore, but the master mounting holes are in the opposite position of the trucks (up and down on the conquest and left and right on the truck).
MightyG54BTMax
Engine Size: 2.6
Re: Brake booster
Postby DroppedMitsu » Mon Sep 21, 2009 11:00 am
Spacing between bottom two studs is ~3 1/8", spacing between bottom and top stud is ~ 2 3/8". I snapped a pic of the brake booster from front of truck if you want that also?
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Re: Brake booster
Postby Spicoli » Mon Sep 21, 2009 4:53 pm
If I was gonna swap M/Cs Id use one from a V6 powered montero/raider/MM the montero guys that arent stock v6 seem happy w/ the upgrade.
--keRby
Ad Inexplorata
Spicoli
Re: Brake booster
Postby pennyman1 » Sat Oct 03, 2009 5:16 pm
Or you can use a 1st gen d-50 booster- they are both up and down mount. Don't know if there is a difference between mounting pattern though.
pennyman1
Return to Brake Systems
