mightyram50.net • View topic - disc brake swap
disc brake swap
disc brake swap
Postby shield88mm » Wed Jan 20, 2010 9:39 am
I have 88 MM 2.0
Looking to get rear disc brakes.
Any direct fits?
shield88mm
Re: disc brake swap
Postby netstat » Wed Jan 20, 2010 10:02 am
my Haynes manual I bough mentioned something about the later models being available with 4 wheel disc. Never seen it tho, so I don't know how much to trust it.
netstat
Engine Size: 2.4L
Re: disc brake swap
Postby pennyman1 » Wed Jan 20, 2010 10:14 am
See my other post entries for brake upgrades for 1st gen- it has info about rear disc brake swap.
Re: disc brake swap
Postby Spicoli » Wed Jan 20, 2010 5:06 pm
Could swap in a late model Montero Sport axle, leafsprings are same spread, u joint would take some work I imagine, I think its about 2in wider or so tho.
--keRby
Ad Inexplorata
Spicoli
Return to Brake Systems
