Carb issues again?!
Carb issues again?!
Postby shield88mm » Tue May 04, 2010 12:16 am
Can anyone tell me how to properly tune the carburetor or provide some place I can reference to?
Here's the deal, I have an 88 MM 2.0 2wd stock carb 8 deg BTDC. Going up a hill on the freeway there is no power in 3rd @ just about redline, 4th or 5th @ WOT or anything else for that matter. I've tried playing around with the idle screw and a screw for some sort of linkage going toward the top of the carb (almost like its vacuum controlled). I almost just want to get a weber (are they cali legal?) but I am concerned with the fact that there are like 20 vacuum lines in the stock and only 1 (I think) on the weber. Plus there is the money issue. On the other hand I can't help but think that the car can run faster (at least to the point where it can climb a hill faster than 55mph) and I believe it to be carb related. I have replaced all the ignition parts (plugs, wires, cap, rotor, coil).
So if there is anyone out there than has any info on how to tune the carb from scratch I would definitely appreciate it.
shield88mm
Re: Carb issues again?!
Postby Ramit » Tue May 04, 2010 5:36 pm
I'm not sure of your particular year, but if it has a vacuum controlled secondary,you might want to check and make sure it is holding a vacuum.If it is leaking, your secondary will not open up at WOT,and your truck will seem to be extremely under powered.It will basically turn it into a 1 barrel carb.
Ramit
Donator
Donator
Postby shield88mm » Wed May 05, 2010 10:01 pm
OK I'll check that out tomorrow. Thanks for the info!
shield88mm
Postby Ramit » Thu May 06, 2010 8:56 am
MaxD50 wrote:I bet Ramit hit it on a nutshell
???????????? Did you mean "hit it on the head"or "thats it in a nutshell" :think: . No more internet past 10:00pm. for you young man!! :lol:
Ramit
Donator
Donator
Postby Ramit » Thu May 06, 2010 12:59 pm
I knew what you meant. I speak some hillbilly myself. Like they say in Crab Orchard TN. "weeunsall gotta stick together."
Ramit
Donator
Donator
Postby wrngwae » Fri May 07, 2010 4:04 am
hahahahahahaha damn hillbillys
or Chinese parts!!!!
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Return to Possible Fuel Problems
