mightyram50.net • View topic - motor problems
motor problems
motor problems
Postby redresurrection » Thu Jun 04, 2009 2:59 pm
when its rainy outside or truck has been running for awhile it will cut out and cut on, the fuel is there but the spark cuts out it will drop below 1,000rpm and i cant rev it higher than 2,000 it pulse's :evil: is it a sensor going out? possibly my O2 sensor???? my truck is a 1993 2.4l fuel injection.
redresurrection
Re: motor problems
Postby Might93 » Thu Jun 04, 2009 3:37 pm
I o2 sensor does almost nothing on a OBDI car, check your wires, plugs, cap and rotor. Check for anything that looks wore down or bad.
1994 Mighty Max, 4G64 block, 4G63 head. HKS cams, Wiseco Pistons, Eagle H Beam rods, .63 t3 turbo, ACT HD Clutch. Dropped 2"
Might93
Donator
Donator
Re: motor problems
Postby DroppedMitsu » Thu Jun 04, 2009 6:43 pm
As maxd50 said check your dist. cap see if there are any cracks or anything and if there is any condensation under the crap. Either one of those problems and it should be replaced. Also check plugs/wires
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Re: motor problems
Postby RusTy Max » Thu Jun 04, 2009 7:33 pm
& coil!
RusTy Max
Engine Size: 2.4L
Re: motor problems
Postby redresurrection » Sat Jun 06, 2009 4:54 am
thanks everyone
redresurrection
Re: motor problems
Postby MMaxx94 » Wed Jun 17, 2009 5:56 am
did you ever find out what your problem was? I have a 94 2.4 EFI and mine has been sounding real rough lately. when i start it it runs fine for a bit then bogs down [i would say under 1000RPM is correct.. although i don't have a tach :roll: ]
if i give it some gas right away it comes back and runs fine for a while again, then repeats the process. if i don't give it any gas when it bogs down it almost dies, and if i wait that long to give it some gas when i push the accelerator it damn near kills the whole truck.
when i'm driving it on the road its fine, but not just sitting idle. we've adjusted my throttle cable, all new spark plugs, wires, and dist. cap... maybe your fix could be the same for the problem i'm having?
94 Max
<Under ConsTrucKtion>
00 Dakota 4X4
V8 Magnum Mud toy =)
04 Mustang [DD]
true dual exhaust, rims, custom audio & interior, lowering springs
http://www.myspace.com/XoStangBabyXo [add mee]
MMaxx94
Re: motor problems
Postby MMaxx94 » Wed Jun 17, 2009 9:44 am
MaxD50 wrote:I hope your maf ain't going bad :o
oh goodness me too
could that be the problem?
94 Max
00 Dakota 4X4
04 Mustang [DD]
MMaxx94
Re: motor problems
Postby MMaxx94 » Wed Jun 17, 2009 9:48 am
MaxD50 wrote:
oh goodness me too
Sounds like it could be the problem.
that sucks. i don't even know where to begin with that
94 Max
00 Dakota 4X4
04 Mustang [DD]
MMaxx94
Re: motor problems
Postby redresurrection » Sat Jun 20, 2009 11:05 am
well fuck
redresurrection
Re: motor problems
Postby redresurrection » Thu Jun 25, 2009 4:10 pm
ill just drive it till it goes kaboom, than find a 305 or 350 to drop in it.
redresurrection
