G63B Really rough idle
So, I've been trying to figure this out since I got my truck and I can't, so I need some help. Today I decided to take a look at what causes my truck to Idle rough so:
I checked the vacuum lines and they seem to be good , But i'm not sure where a couple go or what they even do.
I adjusted the distributor so it is firing at the right time
I checked all the Spark Plug/Coil Wires with an Inductive Timing Light, this is what i think is causing it to idle rough, I checked all the plug wires and they all seemed to work fine, but the first cylinder wire, If I watched the light on the Timing Gun, it would flash constantly, then it would stop for a split second, the Idle would go down then it would return to normal, doing this every 5 seconds or so, so I checked my Coil Wire and it flashed at a steady pace then it would also stop for a split second, the Engine would stutter, then it went back to normal. So I am wondering what to check, The distributor seemed to have clean contacts and the rotor was clean, but I could not check the wires leading from the Dist to the Coil to tell the coil when to fire. So i would like to know what to check to tell if the Coil needs replaced, the Dist needs replaced or if its just the plug wire that needs to be replaced
Thanks,
Andrew
Thanks,
Andrew
