smoking problems
smoking problems
Postby brakeless » Fri Nov 13, 2009 5:23 pm
ok about like 2 or 3 months ago i got my truck fixed it was sitting for about 4 years and it was fixed and wasnt smoking when i took it home from the shop but now its smoking and the smoke is white (if that helps any) what can i do to make it stop?? any help would be great
brakeless
Engine Size: 2.4l
What year vehicle do you own?: 1995
Re: smoking problems
Postby 79D50 » Thu Nov 19, 2009 12:49 pm
replace the head gasket and look for water in the oil.
79D50
Donator
Donator
Postby leonwold » Thu Nov 19, 2009 7:40 pm
if the exhaust smells sweet its head gasket
leonwold
Postby mxmikie » Tue Nov 24, 2009 3:41 am
replace the valve stem seals mitsubishi valve stem seals are junk
mxmikie
Engine Size: 2.4
Postby smitty » Thu Feb 11, 2010 11:12 am
If your truck was sitting for about four years, and you just now got it out and started driving it, chances are you have a broken piston ring. If it didnt smoke at first, and all of a sudden started smoking, yes, it is very possible.
smitty
Engine Size: 2.0
