primer pump
primer pump
Postby biodougsel » Sat Jan 22, 2011 10:03 am
Hello,
I'm a newbie, with two currently in-op 50's. One needs a new head and associated work, the other one needs some starter work and a replacement primer pump--the outside o-ring is gone. I need either a replacement pump or if necessary the complete fuel filter housing with an intact primer pump.
Any help would be greatly appreciated, as these parts are increasingly hard to find!
Runnin' n B100,
Doug
biodougsel
Engine Size: 2.3
Re: primer pump
Postby mikewarme » Sat Jan 22, 2011 7:23 pm
Hi Doug, The primer pump is about $40 new from mitsubishi. If it leaks its the cup washer inside which is part of the primer. Lots of time the housing bore is worn out and even a new primer won't fix it totaly. The whole complete housing with pump is $140 from mitsubishi new.
Mike
PS I have many diesel parts new used etc. PM me with needs
mikewarme
Engine Size: 2.3
Re: primer pump
Postby 4D55 Performance Inc » Sat Jan 22, 2011 11:38 pm
A new housing is well worth the investment.
Engine Size: 4D55
Re: primer pump
Postby cdalejef » Mon Jan 24, 2011 5:28 am
Do any of you have the part number for new housing?
89 Mazda B2600i soon to be 4d56 turbo diesel.
99 Mitsubishi Montero SR
cdalejef
Re: primer pump
Postby biodougsel » Tue Jan 25, 2011 8:51 pm
Thanks, Mike and 4d55 Performance! I did not know I could still get the parts new--that's great news.
Doug
biodougsel
Engine Size: 2.3
Re: primer pump
Postby mikewarme » Mon Feb 21, 2011 4:43 am
Doug please see us whenever you need parts new. Ordering from dealer is expensive. We have back door ways of ordering the parts wholesale through mitsubishi. Example over counter the primer pump is almost $70. Online it is $47.90. We have the books with part numbers etc
mikewarme
Engine Size: 2.3
Re: primer pump
Postby cdalejef » Mon Feb 21, 2011 11:25 am
I'm interested in a complete fuel filter housing for my new 4D56T swap.
cdalejef
Re: primer pump
Postby mikewarme » Mon Feb 21, 2011 5:17 pm
Call me I have these used.
818 268 3012
Mikewarme@yahoo.com
mikewarme
Engine Size: 2.3
Re: primer pump
Postby cdalejef » Sun Feb 27, 2011 9:01 am
mikewarme wrote:Call me I have these used.
818 268 3012
Mikewarme@yahoo.com
I called and left you a message and sent you a PM
cdalejef
Return to Injection and Fuel Systems
