Dammit Mike,42minutes,what took you so long?
wrngwae wrote:Erick, if you look at your waste gate real good you can determine which direction it opens and closes. the actuator i got for you is adjustable to a certain limit. just hook it up and make sure it is pulled all the way up it should be closed. i seriously doubt someone who had the truck b4 you had a backwards waste gate installed. give it a shot what you got to loose. besides if it was wired up when you got it i would bet it was probably wired closed,,,,,i bet they were trying to get more boost out of it not less imo.
Users browsing this forum: No registered users and 8 guests
