4d56t into an 83 d50
Re: 4d56t into an 83 d50
Postby Might93 » Mon May 18, 2009 3:34 pm
8" or 9" is what I believe they are talking about.
1994 Mighty Max, 4G64 block, 4G63 head. HKS cams, Wiseco Pistons, Eagle H Beam rods, .63 t3 turbo, ACT HD Clutch. Dropped 2"
Might93
Donator
Donator
Postby bellavesus » Thu May 21, 2009 9:40 am
i got the 4d56 glow system wired in, but i needed to switch out the ignition switch as the new one has 6 wires and the old one only has 5. as far as i can tell the extra wire is an ig 2 terminal which controls the glow system, and when the key is turned past start, held and the released back to start and then on, the engine starts perfectly. if i sue the onld ignition, theres no such option and the glow plugs are never used, which means engine just turns over for a long time. my main problem with this new system however, is that i cannot get the engine to turn OFF! using both ignition switches, when turned to the off position, it remains running. i have to unplug the connector at the pump, and it cuts out immediately. anyone have any ideas about this? the wiring has been a huge ordeal, i had thought the vehicles glow system and starting systems would be a little more similar, but i never was able to dig up a wiring diagram for the imported engine. anyone have any idea about why the engine wont turn off now?
bellavesus
Postby Might93 » Thu May 21, 2009 10:51 am
Does it try to die but just diesels? Or it doesnt even slow down, just continues to fire?
Might93
Donator
Donator
Postby bellavesus » Thu May 21, 2009 12:25 pm
doesnt even try to die, no difference in RPM or anything..
bellavesus
Postby bellavesus » Thu May 21, 2009 2:49 pm
i was thinking maybe i need to separate my grounds for the solenoid fuel cutoff and control unit , and relays, since i have them all grounding together on the body...
bellavesus
Postby RusTy Max » Thu May 21, 2009 3:04 pm
A ground is a ground. They will not fight each other to try to ground. That isn't the problem!
RusTy Max
Engine Size: 2.4L
Postby bellavesus » Thu May 21, 2009 3:57 pm
what if something wasnt grounded that needed grounding? i am just confused as the vehicle starts fine, and there isnt a drain on the battery when its off. i would think that if the fuel solenoid was stuck in the "open" position, it would draw power. ive been searching the internet all day for wiring diagrams but so far have come up empty handed.
bellavesus
Postby RusTy Max » Thu May 21, 2009 4:03 pm
Goto harbor freight and get a $2 multi-meter and start prodding... you'll find it. :handgestures-thumbup:
RusTy Max
Engine Size: 2.4L
Postby Spicoli » Sun May 24, 2009 8:16 pm
Browsing your post on 4x4wire, about how it will never shut off. I know good ol Tye said when diesels get ran down (granted I saw your motor has 78000) they wont shut off b/c they keep running of the oil on the bottom end perhaps that is the cause have you noticed it using any oil? Perhaps its the ignition in/on the column thats went bad.
--keRby
Ad Inexplorata
Spicoli
Postby RusTy Max » Tue Jun 02, 2009 5:07 pm
Felt we needed our own "diesel" section!
RusTy Max
Engine Size: 2.4L
PreviousNext
Return to Rebuilds
