glow plug relay
glow plug relay
Postby T-Bone » Thu Nov 11, 2010 10:07 am
Hello,
I have yet another question about the relay. So It turns out that 3 out of 4 of the glow plugs were bad. So I replaced those and the truck starts up fine every time. I live in Oregon so it gets down to the high 30's right now. It does seem like the plugs are not firing after start-up however because it will smoke for 5-8 minutes. And once I start driving the relay starts firing in quick successions, like every 1 second it makes that clicking sound and does this off and on for about 5 minutes. It does not seem to do this while the car is parked. Firing so much that it seems like it might break. Could I need a new temperature sensor? Any help is appreciated. Thanks
T-Bone
Engine Size: 2.3l
Re: glow plug relay
Postby 4D55 Performance Inc » Thu Nov 11, 2010 3:26 pm
What year is your truck? Th 83 trucks used a different system than the 84-85 trucks.
Engine Size: 4D55
Re: glow plug relay
Postby mikewarme » Fri Nov 12, 2010 8:03 pm
Your ecu is bad. Every 83 truck does this after years. Ask Spence for the rebuilders info to repair the box.
mikewarme
Engine Size: 2.3
Re: glow plug relay
Postby T-Bone » Fri Nov 12, 2010 8:24 pm
The truck is an 84. Thanks
T-Bone
Engine Size: 2.3l
Re: glow plug relay
Postby 4D55 Performance Inc » Sat Nov 13, 2010 10:16 am
mikewarme wrote:Your ecu is bad. Every 83 truck does this after years. Ask Spence for the rebuilders info to repair the box.
I think this is the correct company I have used in the past.
http://www.foreignecurepair.com/mitsubishi.htm
Engine Size: 4D55
Re: glow plug relay
Postby mikewarme » Sat Nov 13, 2010 7:27 pm
Its def an ecu problem. Less likley to be a loose ground. For sure not the temp sensor
mikewarme
Engine Size: 2.3
Re: glow plug relay
Postby T-Bone » Sun Nov 14, 2010 1:21 pm
Thanks, really appreciate the help
T-Bone
Engine Size: 2.3l
Re: glow plug relay
Postby T-Bone » Sun Nov 14, 2010 2:20 pm
Oh yeah, I was also wondering what the ECU does, and if it it located inside the cab on the passenger side?
Thanks
T-Bone
Engine Size: 2.3l
Re: glow plug relay
Postby wrngwae » Mon Nov 15, 2010 5:19 am
passenger side kick panel
or Chinese parts!!!!
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Re: glow plug relay
Postby 4D55 Performance Inc » Mon Nov 15, 2010 1:52 pm
What's the "MD" part number on the computer?
Engine Size: 4D55
