by T-Bone » Tue Dec 28, 2010 6:28 pm
So I sent the ECU off to the Mitsubishi computer repair shop and they said that it was fine. Except that the contacts under the two little black boxes needed to be cleaned, which he did, and then sent it back. I plugged it in though and it still fires in quick successions after about 5 minutes of warming up. It actually seems like it might be worse. Also, after the initial 5 seconds of the 12v glow plugs, I can hear the computer shut them off and then the truck starts smoking until the truck warms up. In colder weather like the 40's is this smoking normal or should the computer fire 6v to the plugs which it does not seem to be doing? Thanks for any help
