Turbo
Turbo
Postby shield88mm » Thu May 06, 2010 11:13 pm
I am a turbo noob, and I was checking out this site http://www.ssautochrome.com/level.itml/icOid/1489 and saw this T3 SUPER 45 TURBOCHARGER.
Is this feasible for an 88 MM 2.0? If so what else will I need aside from a turbo manifold? How much more power will this produce?
shield88mm
Re: Turbo
Postby 4doorciv » Fri May 07, 2010 1:52 am
Ssautochrome and turboxs were famous on eBay when I first got into turbos. Never did trust the turbos or manifolds in there. The downpipes dong get as hot as the manifolds or the turbos so I assume they are okay. The manifolds were known to crack on the hondas. I'm using an eBay fmic on my truck cause the evo 8 fmic I had had a hole in it, and used a turboxs wastegate on my 4 door civic. That's as much as I trusted em. To each his own though. IMO.
-Ryan-
4doorciv
Engine Size: 4g63
Re: Turbo
Postby TURBORAM » Thu Oct 21, 2010 3:43 pm
I got a 91 dodge ram 50 with a 4g64 will the 4g63t fit in the same motor mounts and bolt up to the trans
TURBORAM
Engine Size: 2.4
Re: Turbo
Postby LSR Mike » Fri Oct 22, 2010 9:20 am
No. The 4G63T can be bolted to the motor mounts using the mounts from a 4G64. BUT the waterpipe inlet of the 4G63T will hit the firewall and the Tranny will not bolt up. The 44G63T is a Narrowblock (12 1/2 inches between lower mounting bolts) VS the 4G64 Wis a Wideblock (13 1/4 inches) There are some very rare Narrowblock 4G64's which came in Vans of a particular vintage.
LSR Mike
#847 F/BMMP
SCTA-BNI/ECTA
LSR Mike
Engine Size: 2.4L
Re: Turbo
Postby TURBORAM » Mon Oct 25, 2010 5:00 pm
then what can i do to get turboed and make some power
TURBORAM
Engine Size: 2.4
Re: Turbo
Postby LSR Mike » Tue Oct 26, 2010 4:55 am
you can do a head swap to a 2.0 DOHC. That gives you access to cams and valve train, Intakes, some turbo options. You need bigger injectors to feed fuel to it, you'll also need some sort of tuning options, a Eprom ECU and DSMLink to tune the EFI, or a total aftermarket AEM EMS. An Intercooler should be considered. There will be some custom fabrication along the way. Once your making power then you'll have to look into a better clutch.
LSR Mike
#847 F/BMMP
SCTA-BNI/ECTA
LSR Mike
Engine Size: 2.4L
Re: Turbo
Postby TURBORAM » Thu Nov 04, 2010 5:37 am
i want my truck to put out about 400 to the wheels and still be a dailey driver a truck i can depend on through the week to get back and forth to work and still make a good pass down the track on the weekends
TURBORAM
Engine Size: 2.4
Re: Turbo
Postby camoit » Thu Nov 04, 2010 7:45 am
Keep in mind there is a major trade off between life span and performance. More preformance = shorter life. more stock = longer life. Youll need to find the price ballance you can afford.
Hay LSR Mike how much you got tied up in that little pile of parts we see in the picture.. Us fans want to know..
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Re: Turbo
Postby LSR Mike » Thu Nov 04, 2010 8:19 am
About $10,000 when you get into all the supporting mods and equipment.
LSR Mike
#847 F/BMMP
SCTA-BNI/ECTA
LSR Mike
Engine Size: 2.4L
Re: Turbo
Postby 4doorciv » Thu Nov 04, 2010 2:55 pm
Then maybe you can do the dohc head swap and built the block to handle turbo. You can always do the dohc head swap and keep it na. Maybe shoot some nos??
-Ryan-
4doorciv
Engine Size: 4g63
