I'm Back
I'm Back
Postby LSR Mike » Fri Oct 22, 2010 6:59 am
With a New Top Speed.
Te record is 154.691MPH. average of 2 runs. I got greedy on my tune for the second run and took out too much fuel.
Seen this before? Engine mods from a year ago. New twin disc clutch is responsible for the speed gains.
Whole Truck
LSR Mike
#847 F/BMMP
SCTA-BNI/ECTA
LSR Mike
Engine Size: 2.4L
Re: I'm Back
Postby Johnboy72 » Fri Oct 22, 2010 8:21 am
Very impressive and very clean man! Congrats!
Johnboy72
Re: I'm Back
Postby wrngwae » Fri Oct 22, 2010 11:39 am
mike long time no see, it looks like you got your truck where you wanted finally....lol for now. im sure there is more in mind.
or Chinese parts!!!!
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Re: I'm Back
Postby LSR Mike » Fri Oct 22, 2010 12:49 pm
It will never go fast enough, you know that! I'm going to work on the Aero package and gearing now, gotta turn 7500RPM to do these speeds. We'll see how long this motor holds out.
LSR Mike
#847 F/BMMP
SCTA-BNI/ECTA
LSR Mike
Engine Size: 2.4L
Re: I'm Back
Postby camoit » Fri Oct 22, 2010 6:37 pm
You have got to be shitting me. Thats some speed evein I could get in to. I hopeing for around 130+ for my rig. But I will need to come up with a speedo. Whats inside the tin??
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Re: I'm Back
Postby LSR Mike » Sat Oct 23, 2010 4:48 am
You don't need a Speedo, just a good tach and an Excel Spread sheet to calculate your speed.
mph = rpm x tire diameter / differential gear ratio x 336/ transmission gear ratio
and for the run of the mill Mighty Max
Diff=3.909, 1st gear=4.33, 2nd gear=2.355, 3rd gear=1.509, 4th gear=1, 5th gear=0.827
Tire Diameter is calculated with, tire diameter = 2 x section width x aspect ratio / 2540 + rim diameter
Mine is 225 section width, 60 aspect ratio, and a 15 in Rim diameter for 25.63 Tire diameter( 225/R60-15)
check here for pix of the 2 blocks I've been thru and various progressions of the builds over the years.
http://mmeierle.com/
LSR Mike
#847 F/BMMP
SCTA-BNI/ECTA
LSR Mike
Engine Size: 2.4L
Re: I'm Back
Postby camoit » Sat Oct 23, 2010 11:16 am
Very nice. You shound drop a build thread in the build section. This site has been in need of a good turbo guy.
My main problem is I have no idea what gear ratios the Tremic T56 LS has in it. There was work done to it befor I got it. All I know is it was fine inside and the shift forks were upgraded. So all I had the trany shop do was reseal after they looked at it. I know the rear end is a 4-11.
camoit
Admin
Admin
Engine Size: 2.6L
Re: I'm Back
Postby Wilbur » Tue Dec 07, 2010 9:13 am
Mike Congrats!!!! Still looks good. Do your Aero Plans include skirts front and and rear to cut down air under your rig?
Wilbur
Engine Size: 2.4
Re: I'm Back
Postby Rahtid » Sun Jan 23, 2011 8:18 am
Are still using the stock fuel rail
Rahtid
Engine Size: 2.4
Re: I'm Back
Postby LSR Mike » Sun Jan 23, 2011 9:05 am
Yes, fuel rail isn't a limitation, much to AEM's Chagrin.
LSR Mike
#847 F/BMMP
SCTA-BNI/ECTA
LSR Mike
Engine Size: 2.4L
