exhaust set up??
exhaust set up??
Postby custom 50 » Mon Jan 24, 2011 6:49 pm
im thinkin about doin some sort of custom exhaust setup on the 50 just curious to see any one elses set up and what kinda mufflers you runnin and how they sound thanks
S--T--R--E--T--C--H
custom 50
Re: exhaust set up??
Postby DroppedMitsu » Mon Jan 24, 2011 6:59 pm
Im running a flowmaster 40 series muffler and I love how it sounds. Not real loud but loud enough to hear it and a nice low.tone
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Postby custom 50 » Mon Jan 24, 2011 7:00 pm
how are you runnin it?
S--T--R--E--T--C--H
custom 50
Postby DroppedMitsu » Mon Jan 24, 2011 7:05 pm
Same as stock
-Josh-
DroppedMitsu
Engine Size: 4g63
Postby custom 50 » Mon Jan 24, 2011 7:08 pm
you just replaced the muffler ? was it the same length?
S--T--R--E--T--C--H
custom 50
Postby DroppedMitsu » Mon Jan 24, 2011 7:12 pm
Yes for now. No it wasn't the same length as what was on there, had to do a little fab'n n weldin
-Josh-
DroppedMitsu
Engine Size: 4g63
Postby capev86 » Tue Jan 25, 2011 11:03 pm
n/a 4 cylinder: 2" pipe w/ low restriction muffler. you want efficiency, not volume. too much space and exhaust velocity slows down hurting throttle response and low end power.
turbo 4 cylinder: 2-1/2" to 3" depending on engine and turbo size
6 cylinder: i'd like to do dual 2" w/ crossover pipe behind a mivec 3.8 in my 87 ram 50. only problem is the fuel tank location, otherwise an old school symmetrical dual exhaust would be awesome
capev86
Postby pennyman1 » Wed Jan 26, 2011 5:12 pm
do like other f/s trucks do - run both pipes down one side until you're clear of the gas tank, then separate them to the rear.
