I've ordered up a MSD blaster coil and 6al-2, I just need a decent set of leads and an electronic ignition so I can ditch the points.
What leads do you guys run? Also does anyone know what distributor the 2.0's run, my supplier can get me a kit which fits the mitsubishi T3T dizzy.
I've already fitted a weber 38/38 (which hesitates then you put your foot down at low revs), custom exhaust, electric fuel pump and fuel pressure regulator. I'll get a load of pics up when its all done
