msd ignition question
Postby siris » Mon Mar 15, 2010 3:00 pm
I'm trying to put a msd in my truck, but can not get a refrence from the distributer. Stock ignition works fine, but when i hook the msd up i get nothing. It's a 2.6l with the mazda dizy. Any ideas?
siris
Re: msd ignition question
Postby pennyman1 » Mon Mar 15, 2010 5:25 pm
which MSD?
Postby siris » Mon Mar 15, 2010 5:43 pm
street fire, i think i found my problem. was trying to hook it up as a magnetic pickup, but its an igniter style dizzy.
siris
Postby paullen » Tue Mar 16, 2010 6:30 am
Remember to only fit the two msd wires to the coil, I made the mistake of leaving the weber electric choke fitted to the + side of the coil and it wouldn't start.
paullen
Engine Size: 2000
Postby siris » Tue Mar 16, 2010 10:30 am
i was wondering what the extra wire on the coil was, should i hook it up to the tach signal off of the box? is it required by the carb to kill the choke?
siris
Postby paullen » Tue Mar 16, 2010 2:00 pm
I had two extra wires because of the weber, the second extra wire looks like a noise suppressor to me, I left it off and its running like a dream.
paullen
Engine Size: 2000
Postby siris » Tue Mar 16, 2010 2:58 pm
an update, my choke doesnt open now after the msd install. it's possible it wasnt before but i now notice it.
siris
Postby siris » Tue Mar 16, 2010 6:49 pm
i was thinking the low side of the ballist resistor, i know alot of e-chokes are not supposed to get constent battery voltage. it will burn them up.
siris
Postby pennyman1 » Wed Mar 17, 2010 9:16 am
Don't use any power from either side of the coil for the choke, it will draw too much power from the ignition and cause the limiter in the factory tach to trip prematurely and shut off power until it drops below the "limit". Learned this the hard way. Your MSD will not affect the system.
Return to Ignition Upgrades.
