mightyram50.net • View topic - may not have a 4th gear!
Re: may not have a 4th gear!
Postby wrngwae » Wed Jul 22, 2009 3:31 am
yea on the auto trans ther is a temp sensor in your intake that allows the trans to go into O/D......check under your carb i think it was there on my raider. the switch wil just go to ground when heated so if you sucpect that is it just ground that wire and see if it goes into O/D...
or Chinese parts!!!!
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Postby trash » Wed Jul 22, 2009 4:12 am
Thanks, I'll give it a try I've got nothing to lose:)
EDIT: Might have to head back to the dealership, they wanted to drop the trany oil pan to change filter if needed but also to tighten bands... can anybody give me a rough idea of cost so i don't get gouged again.. reason is there is slipping between 1 ans 2nd gear.
cheers:)
1991 Ram50 sport, motor 4g64, trans r4ac1, model K15TUESEL3
trash
Engine Size: 2.0
Previous
Return to Transmission.
