may not have a 4th gear!
Re: may not have a 4th gear!
Postby trash » Fri Jul 10, 2009 4:35 pm
Hehe, it's so complicated! Mitsu told me to get the part # from a Chrysler dealer.. i'm gonna go check a bigger scrap yard next week.
1991 Ram50 sport, motor 4g64, trans r4ac1, model K15TUESEL3
trash
Postby Spicoli » Fri Jul 10, 2009 4:38 pm
If someone here has a truck w/ the same tranny but a mitsu ask them if you can borrow there vin take it to mitsu tell em you need the solenoid for this MITSU vin
--keRby
Ad Inexplorata
Spicoli
Postby trash » Fri Jul 10, 2009 5:19 pm
Actually I decided the oxygen sensor was more important than the OD solinoid and fortunately the dodge dealer gave me the part # for the sensor although it's a bosch part #... so i just emailed Mitsu with that info. Maybe tomorrow i'll just check Canadian tire to see if they have one.. but so far the cheapest oxygen sensor I have found it $170. canadian!
trash
Postby niftyd50881 » Fri Jul 10, 2009 9:38 pm
they asked for a vin or some form of confirmation just to inquire about a part #?
i could see chrysler doing something so stupid since everything seems to be keyed to the vin on their cars nowadays.
man, with all this unemployment around how do such lazy ass people keep thier jobs.
if they wouldve asked me at the mitsu dealer for my vin when i went to get my ignition switch i wouldve showed them, by driving the truck thru the door so they can get a better look.
what a load of crap!
take your old one off then take it there and shove it in thier faces and ask if they have one and how much.
even better, get the part number off the thing and search ebay or google bound to be someone selling one somewhere.
niftyd50881
Engine Size: 2.6l
Postby Might93 » Wed Jul 15, 2009 5:02 am
An O2 sensor should be right around 40 bucks for one of these trucks. Its just a 3 wire heated O2 sensor I would imagine. Dont buy ANYTHING from a stealership without looking around first
1994 Mighty Max, 4G64 block, 4G63 head. HKS cams, Wiseco Pistons, Eagle H Beam rods, .63 t3 turbo, ACT HD Clutch. Dropped 2"
Might93
Donator
Donator
Postby trash » Wed Jul 15, 2009 6:05 am
NGK 21001 $49.93 +tx :)
stealership indeed!
trash
Postby pennyman1 » Tue Jul 21, 2009 6:57 am
I once had a 88 Ram 50 with the Auto OD tranny and had no OD. The fix? the solenoid is grounded to the Intake manifold under the throttle body. I had changed a sensor on mine and unplugged it somehow. It is a single black wire out of the harness. Hope this helps!
Postby trash » Tue Jul 21, 2009 7:36 am
I got all excited when i saw a single black wire dangling but it turns out it was just a ground from the starter. Sadly the rest of the single black wires are plugged snugly... thanks for posting though, i bet it will help somebody someday!:)
trash
Postby pennyman1 » Tue Jul 21, 2009 6:06 pm
Also be sure you don't have the temp sensor lead and the solenoid wires switched- that is what I did. There is no separate ground wire from the starter, it grounds to the block and tranny. That wire will appear to come from the starter, its in the bundle coming up from there.
Postby trash » Tue Jul 21, 2009 6:37 pm
when you talk temperature sensor is it the guage for hot/cold because the guage seems to be reading correctly. If not then i'll mention it to the garage tomorrow as they now have my truck again.. came out of the grocery store tonight and the truck wouldn't start at all, they thinks the coil went.:(
trash
PreviousNext
Return to Transmission.
