mightyram50.net • View topic - Neutral Safety Switch Location, 1990 Ram 50
Postby Alohauser » Thu Dec 02, 2010 1:08 pm
Aloha
I'm trying to locate the Neutral Safety Switch on my 1990 Dodge Ram 50, 4 cyl. Any help will be appreciated!
Thanks
Alohauser
Engine Size: 2.4
Re: Neutral Safety Switch Location, 1990 Ram 50
Postby DroppedMitsu » Thu Dec 02, 2010 1:25 pm
Haynes manual says its on the side of the transmission, looks like its by the oil cooler lines and throttle/gear shift lever
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Postby 92slammedmitsu » Thu Dec 02, 2010 5:31 pm
Alohauser wrote:Aloha
Thanks
Its a little button on the back side of the clutch pedal that depressed when you dont have you foot on the clutch just unbolt it and it will always be unpressed so it will allow you to start the truck without the clutch pressed in .
92slammedmitsu
Engine Size: 2.4
Postby Alohauser » Fri Dec 03, 2010 6:01 pm
This is an automatic, so it's the park or neutral position safety switch I need to change.
Alohauser
Engine Size: 2.4
Return to Transmission.
