Transmission Compatibility?
Postby ipods.rocks » Wed Dec 08, 2010 3:02 am
Hey guys, im new here (obviously). im just here to ask you guys if a transmission from a 91 4x2 2.6 sport is compatbile with my 1988 4x2 2.6 sport.
Thanks guys
Joshua N.
ipods.rocks
Re: Transmission Compatibility?
Postby DroppedMitsu » Wed Dec 08, 2010 8:20 am
2.6 to 2.6 and both 2wd u should be good to go. If u want to make sure measure the length apart of the two bottom bellhousing bolt, if they are the same length apart then it will work.
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Postby capev86 » Wed Dec 08, 2010 2:13 pm
only 4 cylinder in front of that transmission in '91 was the wide block 2.4. it should fit the wide block 2.6 in an older rig.
capev86
Postby ipods.rocks » Thu Dec 09, 2010 12:35 am
capev86 wrote:only 4 cylinder in front of that transmission in '91 was the wide block 2.4. it should fit the wide block 2.6 in an older rig.
wait, so even if it isnt a 2.6, should the tranny fit?
ipods.rocks
Postby DroppedMitsu » Thu Dec 09, 2010 9:00 am
yes, if it is a fuel injected 2.4l (4g64) the tranny will still work.
-Josh-
DroppedMitsu
Engine Size: 4g63
Return to Transmission.
Users browsing this forum: No registered users and 13 guests
