using 4g63 clutch and flywheel on my truck
Postby pennyman1 » Sat Feb 26, 2011 7:09 pm
Will a 6 bolt AWD 4g63 flywheel and clutch set work with either my 1980 2.6 5spd or 1986 2.0 5spd trucks? I have a chance to get a stage 2 fidanza clutch pressure plate and xtd flywheel for a great price, but I don't remember if they will work on these trucks or not. LMK quickly - I have only 24 hours to make the deal.
Re: using 4g63 clutch and flywheel on my truck
Postby 4doorciv » Mon Feb 28, 2011 2:00 am
The 4g63 turbo flywheel would not be reachable with the awd flywheel, but would be with the fwd flywheel. This is true with the narrow blocks. The truck clutch disc would be a little smaller with the dsm pressure plate and flywheel and would be more suited with the star quest oem cluth dimensions. Running the dsm clutch disc in the truck pressure plate and flywheel is something I haven't thought about but I am sure it will stick out of the pressure plate a bit. Also the clutch spline would not fit on the trucks input shaft like the starion or conquest discs and the dsm flywheel doesn't have the pilot bearing in it, that would need to be machined in.
Just some research from doing a 4g63 turbo swap. :)
-Ryan-
4doorciv
Engine Size: 4g63
Postby pennyman1 » Mon Feb 28, 2011 11:18 am
Ya I found that all out after I posted it, althiugh the 3.0 v6 disc with the fwd flywheel and pp seems to be the hot ticket with 4g63 swaps
Postby 4doorciv » Mon Feb 28, 2011 1:28 pm
Interesting. Is the v6 disc the same as the starion turbo disc? More options would open up.
-Ryan-
4doorciv
Engine Size: 4g63
Postby pennyman1 » Mon Feb 28, 2011 3:32 pm
not sure - its on the hodrodcoffeeshop site - the splines are the same 1x23 as the conquest, but other than that I can't say for sure
Postby 4doorciv » Mon Feb 28, 2011 5:30 pm
Okay. I got my info from projectzerog for the starquest clutch disc setup.
-Ryan-
4doorciv
Engine Size: 4g63
Return to Transmission.
Users browsing this forum: No registered users and 32 guests
