trans swap and gear issues
Postby TotallyBalistic » Sun Sep 06, 2009 9:16 am
heres the deal, i swapped a g52 into my macro with a 4 speed then finally (many thanks to kerby) i ended up with a 5 speed to slap in her. i bought a new clutch kit and got the tranny in but now ive got 3.545 gears and a 5 speed and its eatin me up in town with the high gear ratio and i still have no pick up power for jumpin on the highways...would it be worth my time to throw a 3.909 rear under the truck or what. im not runnin large tires just 225 60 16s on aluminum wheels
595
TotallyBalistic
Good Times
Good Times
Engine Size: 2.0
Re: trans swap and gear issues
Postby DroppedMitsu » Sun Sep 06, 2009 9:34 am
If you are looking for a little more torque for that extra get up then I think swapping to a 3.90 might solve your problem. I think there is too little of gear with my 5speed and 3.90, so I'm looking to go to 3.545 for a little lower highway rpm.
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Postby TotallyBalistic » Sun Sep 06, 2009 10:00 am
on the highway i loose some speed goin uphill and find myself mashin the gas harder so i know thats eatin up my mpgs, i guess im just used to v8s and havent had a 4 cylinder since my 4x4 was stock
595
TotallyBalistic
Good Times
Good Times
Engine Size: 2.0
Postby Spicoli » Sun Sep 06, 2009 7:00 pm
Russ if you want, Ill swap ya a set of 3.909s for 3.545s. Gimme a holler you got my number
--keRby
Ad Inexplorata
Spicoli
Postby TotallyBalistic » Thu Sep 10, 2009 2:10 pm
so far mpgs are doin good im gettin about 370 miles to a tank it would probably do better if i drove it alittle better but oh well...ill probably leave the 3.545s in the truck for a while
595
TotallyBalistic
Good Times
Good Times
Engine Size: 2.0
Postby Spicoli » Thu Sep 10, 2009 6:18 pm
Glad to hear it, this weekend the 2wd is getting the 3.545s and the LSD for the time being until I get the red one running.
--keRby
Ad Inexplorata
Spicoli
Return to Transmission.
