2.0 5 spd to auto swap
Postby pennyman1 » Tue Jan 26, 2010 7:38 pm
On my 86 d-50, it currently has the 2.0 and 5 spd. Can I swap out the 5 spd for the auto without changing the block? I'm thinking they are both narrow block motors- I know all the gory swapping details and have a 2.6 auto parts truck. Want to keep the 2.0 for economy for a while.
Re: 2.0 5 spd to auto swap
Postby Spicoli » Tue Jan 26, 2010 7:46 pm
I beleive the 2.0 autos came wideblocks but cant say 100%
--keRby
Ad Inexplorata
Spicoli
Postby 4cylinders » Tue Jan 26, 2010 9:05 pm
hey, 86 2.0 G63B is a narrow block. the big problem will be the trans tunnel. the auto trans tunnel is wider to clear the linkage and accumulator on the 904 trans. that trans does not have overdrive.
4cylinders
Postby pennyman1 » Wed Jan 27, 2010 6:54 pm
Glad you confirmed that the auto trucks have wider tunnels- others on here thought I was nuts. Its probably staying a 5 spd anyways.
Postby 77amc » Thu Jan 28, 2010 6:12 pm
The 86/87, 2.0 that I got with the auto trans was a wide-block! The 5spd 1st gen 2.0 was a narrow block from what I've read/told. I can snap some pics for you of the auto bolt pattern.
E
77amc
Postby capev86 » Sun Nov 14, 2010 6:48 pm
with that little 2.0, you are better off sticking with the 5spd for economy and performance reasons. only reason i could see to give up a stick for an auto is strictly for drag racing, dedicated tow vehicle or if you are disabled. any way you look at, you will want the better low end punch of the 2.4 or 2.6 with an auto!
capev86
Return to Transmission.
Users browsing this forum: No registered users and 7 guests
