re gearing for bigger tires
Drive Line & Rear End Problems.
Postby 83powerram50dan » Fri Dec 04, 2009 10:32 pm
could any one tell me the best gears to put in my 83 dodge ram 50 for my 2.6 to turn 35 in tires
83powerram50dan
Re: re gearing for bigger tires
Postby 77amc » Sat Dec 05, 2009 10:59 am
You don't state what you are driving on..?
For Highway, 3.90:1 or lower (numerically) and for crawlin, 4.22:1 on up..
E
77amc
Postby Spicoli » Sat Dec 05, 2009 1:45 pm
Hope you got some tricks up your sleeves to fit 35s on a first gen. 31s all you can really fit with a BL and torsion cranks. Unless you cut fenders.
--keRby
Ad Inexplorata
Spicoli
Postby 83powerram50dan » Sat Dec 05, 2009 8:14 pm
imm gonna change out the the axel and put yota on them and than lift it from there
83powerram50dan
Postby TotallyBalistic » Sun Dec 06, 2009 2:22 am
so are you doing a straight axle swap or what
595
TotallyBalistic
Good Times
Good Times
Postby 83powerram50dan » Mon Dec 07, 2009 6:15 pm
purdy much imma gonna try and get the 35s on it every one is telling me it would look good on 35s imma try getting a pic of it up soon
83powerram50dan
Postby BCDieselD50 » Tue Dec 08, 2009 11:49 pm
83powerram50dan wrote:imm gonna change out the the axel and put yota on them and than lift it from there
im lookin into SAS, what yota axle would ya suggest for this ?
BCDieselD50
Postby Spicoli » Wed Dec 09, 2009 8:28 am
Does yoter make a Driverside drop axle? Outside of there 8in SFA that came in the trucks I'm not real fimiliar with there SFA's.
If I was gonna keep a truck stock, I'd get a early bronco front D44 that driverside drop, or a old D44 6lug wagoneer, relative same width same pattern same drop side.
Out side of that your looking at divorcing your t case and tranny, wich I know of one person thats done that. And I dont think divorcing one would be very easily done without lots of lift. Tho I know the montero guys can fit a np231 behind there 4cyl auto tranny with about one new seal, so realistically, you could run something pside drop with a married set up.
--keRby
Ad Inexplorata
Spicoli
Postby 83powerram50dan » Wed Dec 09, 2009 3:32 pm
depend ing on what model your truck is on what one you what...
and is the bronce a full size one or what
83powerram50dan
Postby TotallyBalistic » Wed Dec 09, 2009 8:14 pm
yota axles are pretty stout...it sounds funny but i have seen people cross drive shafts from the drivers side drop t-case to passenger side third members...seen them in some rock crawlin videos and seen a couple at the mud bogs
595
TotallyBalistic
Good Times
Good Times
Return to Propeller Shaft & Rear End.
