mightyram50.net • View topic - Powertrax Lockright
Powertrax Lockright
Drive Line & Rear End Problems.
Powertrax Lockright
Postby 4cylinders » Mon Dec 07, 2009 6:01 pm
hey, would be nice to have better traction. richmondgear.com/ maybe they would build one for these trucks if there is enough interest. click on tech support to let them know we want them. what years use the same carrier and axle splines, 79-89 or more?
4cylinders
Re: Powertrax Lockright
Postby 4cylinders » Thu Dec 10, 2009 12:17 pm
hey, has anyone got any feedback from richmond? anyone have any leads on a better setup? sure would be nice to get better traction.
4cylinders
Postby 4cylinders » Fri Dec 11, 2009 8:21 pm
hey, after some research, they make one for a ford 8". very similar to the mitsu, uses the stock side gears. anyone happen to have an 8" out of the vehicle to get some specs? or an 8" side gear to compare?
4cylinders
Postby Spicoli » Sat Dec 12, 2009 10:37 am
Whats wrong with finding a stock LSD at the j/y? Or welding it or just axle swapping it??
ARB, makes lockers for em for 1000, but dont offer em for the rear 8in mitsu, its kind of a dead technology. Lockrite makes em for the front 8in that came in v6 rigs but they run a different spline count.
Your pissing in the wind with this thread IMO.
--keRby
Ad Inexplorata
Spicoli
Postby 4cylinders » Sat Dec 12, 2009 10:59 am
hey, haven't found an lsd, welding not good on the street.trying to find a solution without throwing a lot of money/time at it.
4cylinders
Postby 4cylinders » Wed Dec 23, 2009 7:54 pm
okay, next step, make a prototype. friend of mine has a small shop, so here we go, be back when we get something solid.
4cylinders
Postby 80D50SPORT » Tue Jan 12, 2010 7:19 pm
TELL YOU WHAT THROW $200 PLUS SHIPPING MY WAY AND YOU TRACTION PROBLEMS WILL BE SOLVED! I HAVE A LSD OUT OF A RAIDER STILL HAS 4.62 GEARS IN IT .... I CAN GET EITHER 3.91 OR 3.55 AND SET IT UP FOR YOU FOR A LITTLE MORE IF YOUR INTERESTED ...
80D50SPORT
Return to Propeller Shaft & Rear End.
