mightyram50.net • View topic - MORE TRACTION WITHOUT TRACTION BARS !
Drive Line & Rear End Problems.
Postby 80D50SPORT » Tue Jan 12, 2010 7:25 pm
ON ANOTHER FORUM THERE IS A FELLA WITH A TURBO'D 4G TRUCK THAT RECENTLY INSTALLED TRACTON BARS ON HIS TRUCK BUT THE CONCERN IS THAT THEY WOULD CAUSE GROUND CLEARENCE ISSUES FOR LOWRED TRUCKS .. I HAPPEND TO REMEMBER THE ON MY 85 440 POWERED D-100 FULL SIZE I REMEMBER USING LEAF SPRING CLAMPS ! THEY WORK LIKE A CHAMP AND WILL NOT CAUSE ANY ISSUSE WITH LOWRED TRUCKS ...JUST CLAMP THE FRONT SIDE OF THE LEAF SPRING....
AND CHEAPER TOO.. OR YOU COULD JUST MAKE YOUR OWN LIKE I JUST DID THIS WEEKEND FOR MY TRUCK..
http://www.summitracing.com/search/Bran ... toview=SKU
80D50SPORT
Re: MORE TRACTION WITHOUT TRACTION BARS !
Postby pennyman1 » Wed Jan 13, 2010 6:54 pm
JCWhitney and others used to sell a traction bar setup that bolted on above the axle. Or modify a trac bar from a late model camaro to keep the axle from twisting.
Return to Propeller Shaft & Rear End.
