mightyram50.net • View topic - tailgate
tailgate
tailgate
Postby oakley » Thu Dec 02, 2010 6:06 pm
how do i remove the dodge lettering on my 89 ram 50 tailgate
oakley
Engine Size: 2.4l
Re: tailgate
Postby beachrat92 » Thu Dec 02, 2010 9:07 pm
I have only done it on our van to get the striping on the side off but The way i did it was to use a hair dryer to heat up glue behind the sticker and peal it back slowly it should work for this to.
- Dan
beachrat92
Engine Size: 2.0
Re: tailgate
Postby pennyman1 » Fri Dec 03, 2010 8:11 am
3m sells a vinyl and adhesive remover that will loosen the sticker and dissolve the glue. 3m also sells a vinyl eraser that uses a drill motor to erase the sticker and glue without damaging most finishes. If you go the hair dryer route you still need something to take off the glue. Charcoal lighter fluid works well for adhesive removal, and can sometlmes work to remove stick on graphics. It is Naphta solvent, also known as Benzene, and will not attack most finishes, but will remove any wax on the finish. It is even sold as bug and tar remover, and will remove road line marking paint if its still fresh.
pennyman1
Return to Body, Frame & Paint
