So on my 89 power ram 4x4 the front end sits quite a bit lower then the back end... I was wondering if there was any way to tweak the front end up a little higher so the truck looked more level rather then looking jacked up in the back end?
Thanks
DroppedMitsu wrote:Your 4x4 should have torsion bars. You adjust them from under the cab and you can probably get it close to level.
