93 MM bumper cover questions
Postby payrion » Sun May 23, 2010 1:41 pm
trying to decide on a bumper to use, its between a 4runner and the 93 up bumper cover, for the bumper cover, what parts are needed under the cover to make this work, i found a place that has the cover support and right and left brackets, sre there other parts needed under there?, iuve never seen one in real life and there isnt any in the yards out here to look at.
payrion
Re: 93 MM bumper cover questions
Postby DroppedMitsu » Sat May 29, 2010 2:31 pm
you should be able to get away with just those two brackets and reinforcement support
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Postby lush90 » Sat Oct 02, 2010 9:05 pm
I just put the 93 and newer bumper on my 91 and it was really easy. The bumper cover is held on by plastic tabs on the top backside of the bumper support. It is not necessary to touch these (plus they look like they might snap off). There are 3 or 4 bolts (10mm, I think) underneath the center section that need to be removed. That allows you to pivot up the bumper cover to access 4 (14mm) bolts that hold on the two brackets on either side of the license plate. These brackets replace the pair on your vehicle now. Each side bracket has 2 (12mm) bolts. It was very straight forward and I'm trying to find another one for my '90.
lush90
Engine Size: 3.0
Postby oakley » Wed Dec 01, 2010 9:39 pm
will a 93 bumper cover for mm fit a 89 ram 50
oakley
Engine Size: 2.4l
Postby minimitz » Mon Jan 10, 2011 12:16 pm
yes it will fit fine, you'd be suprised to know how much you can swap around on these trucks
minimitz
Engine Size: 2.4
Postby 4doorciv » Mon Jan 10, 2011 4:41 pm
Yep. A lot of stuff van be swapped around. Not just bumpers, and not just with other Mitsubishi trucks. Some Mazda and Nissan stuff fit also.
-Ryan-
4doorciv
Engine Size: 4g63
Return to Body, Frame & Paint
