Front end leveling?
Front end leveling?
Postby 89powerram » Sun Mar 20, 2011 11:33 am
So on my 89 power ram 4x4 the front end sits quite a bit lower then the back end... I was wondering if there was any way to tweak the front end up a little higher so the truck looked more level rather then looking jacked up in the back end?
Thanks
89powerram
Engine Size: 2.6L
Re: Front end leveling?
Postby 4doorciv » Sun Mar 20, 2011 12:55 pm
You mean you don't like the oem rake of the front? Well, it's about a 2 inch difference front and rear. You can raise the front 2 inches or add drop blocks to the rear to lower the rear.
-Ryan-
4doorciv
Engine Size: 4g63
Postby DroppedMitsu » Sun Mar 20, 2011 1:02 pm
Your 4x4 should have torsion bars. You adjust them from under the cab and you can probably get it close to level.
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Postby LethalEthan » Sun Mar 20, 2011 1:05 pm
DroppedMitsu wrote:Your 4x4 should have torsion bars. You adjust them from under the cab and you can probably get it close to level.
+1. I'm almost positive you can get it level that way. You may need to get shocks though
LethalEthan
Engine Size: 2.3L
Postby pennyman1 » Sun Mar 20, 2011 6:10 pm
Or you could swap out the upper control arms with ones from a first gen montero
pennyman1
Postby 89powerram » Wed Mar 23, 2011 9:26 pm
Ok Iv never done anything with torsion bars before... Ive installed a lift kit on a leaf sprung 80 Chevy 4x4 but these torsion bars are new to me...
Is this fairly simple to do....?
89powerram
Engine Size: 2.6L
Postby 4doorciv » Thu Mar 24, 2011 12:41 am
With torsion bars, all you have to do is use a tape measure to a specified point, and crank on the adjustment point to the desired ride height. You can go a little deeper and re index the torsion bar, but that involves removing the torsion bar and reinstalling the torsion bar in a reindexed manner. Aka turn one flat or more in the desired direction to keep oem quality ride comfort at a different ride height. That relieves some stress on the torsion bar. Learned this from Mazda b series guys.
-Ryan-
4doorciv
Engine Size: 4g63
Return to Body, Frame & Paint
