mightyram50.net • View topic - Door Panel
Door Panel
Door Panel
Postby Robert » Fri Jan 14, 2011 8:34 am
Can some one help me with how to take the door panel off of my 89 Ram 50? I've gotten as far as popping it out, But I can't get that silver trim out that is between the inner part of the window and the inside of the door panel, I don't want to break it so how do you take it off?
Robert
Re: Door Panel
Postby 94mitz » Fri Jan 14, 2011 9:26 am
i think theres like 4 or 5 clips holding it on. I just flipped the door panel up and pulled on it firmly with one hand on each side of the door panel and mine came off
94mitz
Engine Size: 2.4
Re: Door Panel
Postby Johnboy72 » Fri Jan 14, 2011 9:47 am
I'll try to get some info for ya. But yeah, it was originally designed to just pull out.
Johnboy72
Re: Door Panel
Postby Robert » Fri Jan 14, 2011 11:36 am
Ok thanks
Robert
Re: Door Panel
Postby Robert » Fri Jan 14, 2011 10:02 pm
Hey 94mitz, were you able to put it back in place easily?
Robert
Re: Door Panel
Postby mikewarme » Sat Jan 15, 2011 6:13 am
Robert, Like 94 said..... Except I recommend having help to hold it so it doesn't tear due to age.
Roll window down all the way
Flip door panel up
Than apply pressure to back of window scraper. (Maybe use a small Flap screwdriver to get behind.)It pops off with about 6 clips. Note the clips are part of the scraper and stay on the scraper. They don't come loose.
To install reverse procedure
mikewarme
Engine Size: 2.3
Re: Door Panel
Postby Robert » Sat Jan 15, 2011 10:26 am
Alright, I wil try that and get back to you guys, thanks for the help
Robert
Return to Upholstery, Hardware, Pedals & Windows
